Unless you’re using very restrictive radiators and blocks, don’t worry about.
When I tried 3 Corsair XR5 360 and 2 Alphacool blocks I noticed the flow was badly affected. Angled fittings will impact more if used straight at the output of the pump. Everywhere else, not as much.
The D5 is my favourite pump. Never had any issue and never had to run one at 100%.
You may play around and find exactly at which % your pump is quiet, as it changes from unit to unit, and leave static at that.
Used dual pump before and unless you’re struggling with flow, you won’t see any improvement.
Basically you need to find the correct balance where the coolant spends enough time in the block and then in the radiators to shift temperature.
Personally I like EK radiators, but not the slim ones. PE performed very well and aren’t restrictive at all. XE the same, but you need push/pull or high RPM to make the most of them.
EK blocks are fine. Just check they’re assembled correctly, as lately quality control have been a lottery.
Used a D5 for dual PE 360 + XE 360, monoblock and GPU + Active backplate and plenty of angled fittings. No issue.
Measuring flow at the time, as mentioned before, only when I used an angled fitting at the out port of the pump I noticed significant drop in flow.
