hi my bro flogged me his zalman reservator very cheap i couldnt refuse i thought id get it intentionly just to cool the graphics card x1800xt eventually i will be crossfire
and at the same time my order was in progress half the order has already arrived so ill tell ya what i will have and to hook all together with best tubing route
i have [ ]=ariving soon
1x black ice stealth triple rad
1x tripple nexxxos extreme rad
1x 250mm xspc red alloy res
1x 500mm xspc black alloy res [ received today]
1x Danger den tdx cpu block for 939
[1x gfx water block probley ZM-GWB3 Water Cooling VGA Block]
[1x gfx ram water block again not got as yet] ZM-RWB1 VGA RAM Water Block
1x zalman res no cpu block just that hopefully the reservator pump will help as well
1x hydor l30 pump
1x chipset waterblock
have 10mm tubing but im converting to 1/2 on all so itll be better
some people may say this is too much but i couldnt refuse not buy the reservator of him
so how would you do this with the tubing and with 3.2 litres of water it should cool everything
what temps do ya think ill get?
1x hydor l30 pump
