2 Mar 2012 at 18:21 #1 sehcure sehcure Associate Joined 24 Dec 2011 Posts 990 I can get my hyperX grey to run at 1866mhz, but I have to loosen off the timings to 10-10-10-27. Is this better than running it at 1600 with 9-9-9-27?
2 Mar 2012 at 18:30 #2 thezakarum thezakarum Associate Joined 22 Oct 2010 Posts 1,206 Location Hampshire You can probably test this by running super_pi while at 1600mhz settings then trying 1866mhz settings then compare how fast it completes it.
2 Mar 2012 at 19:44 #3 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 You have an i5-2500K? Running at 1866MHz makes very little difference to 1600MHz. The Best Memory for Sandy Bridge Sandy Bridge Memory Scaling Choosing The Best DDR3 DDR3 SDRAM for Sandy Bridge: Choosing the Best Memory for LGA1155 Platform And what sort of voltage are you using for 1866MHz? (see my sig.) Last edited: 2 Mar 2012
