Im with BT and have been with them for years.  I have a 2mb connection.  Im sharing the connection with a pc downstairs.  Im connected to a wireless router via a wireless adapter and the downstairs pc is connected via an ethernet cable.  The downstairs pc's connection is working perfect but mine is playing up.  Im using the windows firewall and NOD32 anti virus software.  My router has a firewall as well.
Everything was fine until a few days ago when Azureus and Limewire both stopped working. Azureus was saying java(w).exe is unable to act as a server due to firewall. Limewire wont even start because it says a firewall is blocking it. So i turned off windows firewall, un-installed all java, azureus and limewire, run a spyware scan using spyware doctor and a virus scan. Re-installed java azureus and limewire and still no luck. Turned the firewall back on. I thought maybe BT have blocked all peer2peer activity from my pc but now my internet connection keeps going. One minute im browsing the web and then page cannot be displayed with the following target being displayed in the status box at the bottom of internet explorer "C:\WINDOWS\system32\shdoclc.dll/dnserror.htm". If i restart my pc the connection comes back.
Im gonna re-install windows in the next few days and i hope this will solve the problem. Ive also used a program called Security Task Manager to eliminate processes that might be interferring with my connection but still no luck.
Any ideas? Cheers.
Any ideas? Cheers.
