Losing space with ext3/RH9?
29 Oct 2004
I'm a bit stuck with this one, so hopefully someone can either point out what I'm doing wrong or tell me this is normal:
Basically I'm trying to setup a RAID5 array of 3x320GB seagate disks on RedHat9 (best distro Promise provide drivers for). Under XP and Vista I had 596GB usable space using NTFS. On EXT3 I seem to have ended up with considerably less. Firstly I'm about 9GB down (2%) for the listed size, and secondly I'm down 30GB when it comes to available space. I created the partitions using 'parted' as listed in the RH9 manual and made sure I used the whole capacity, indeed it listed the partition as 610000M in parted which = 596G.
Code:
Filesystem            Size  Used Avail Use% Mounted on
/dev/hda2              74G  1.7G   69G   3% /
/dev/hda1              99M  9.4M   85M  10% /boot
none                  488M     0  488M   0% /dev/shm
/dev/sda1             587G   33M  557G   1% /mnt/storage
When it was formatted as NTFS I'm pretty sure it listed Size as 596G as it was on Windows, so I'm a little stumped as to what's losing me 39GB!!
Got rid of the Super User reserved space using tune2fs -m 0 /dev/sda1 and the 2% loss just looks like something I'll have to live with using ext3
