Losing the will to live.
11 Nov 2009
Edinburgh
This has really got me baffled as this PC I am trying to put together will not stay powered on.
It became necessary to replace the motherboard otherwise everything has been running fine.
Bought a Gigabyte X570s UD and a new case, committed a schoolboy error and did not check that the GPU actually fitted the case which it didn't, not a biggy as I can offload the case and have ordered another.
But I thought I would get every ready, windows ETC installed as the case will not be here until next week.
So barebones system on a wooden stool and Windows installed but it will randomly power of, doesn't seem a set time it will just turn itself off.
I have no idea where to look for a solution.
Any thoughts?
Tried turning off all low power states (c-states)? I've had this with very old PSUs that can't handle them, but that's usually on an Intel system.
What CPU are you using?
Got XMP / DRAM voltage 'n stuff set up right?
Double checked all the power connectors are firmly seated?
Will look into your suggestions tomorrow folks but I think there may well be a CPU cooler issue, something does not look right.
Thanks all for your suggestions.
