Losing wireless connect (especially at night)
15 Feb 2003
Europe
I have a kcorp silver PCI wireless G connection to the router to upstairs in my house. The house is prety small so the router is not very far away. When I first boot up I connect to router and signal strength is excellent and speed is 54mbs. However ever so often maybe 4-12 hours (especailly at night) I lose connection to the router. IF i do a site scan windows cannot find any wireless networks, yet if i diable the card then re-enable it, it finds the router immediately and connects again with Excellent signal and 54mbs.
Can anyone help mew solve this issue at all?
Microwave oven? TV or Stereo equipment too close to router? Local military radar? Pirate Radio? ;)
You could try moving the router around a bit. See if it can sit in a better location.
OR.... go into Device Manager, and find your WiFi card. Then open up the properties and turn off any power saving features. (There is usually a page for this). Your card could be falling asleep...
power saving is turned off and we do not have an corless phone, video senders etc.. its strange, this morning my signal dropped to 5.5mps then i turned the card off and on and it was back at 54mbs with very good signal strength.
I had a similar issue on my laptop, turned out to be a major problem with the wireless card's driver, the latest one sorted it out.
I have the latest drivers and have even moved the router to less than 2M away from my wireless card and it still loses the signal from time to time. Scanning for networks then doens't detect anything, and the only way to regain a connection is to disable the wireless card then instantly re-enable it.
someone must have experienced this?
Back to your original post... you say it is a "kcorp silver PCI wireless G". I have never heard of "kcorp", so I assume this is a cheap generic WiFi NIC. In the world of computers "you get what you pay for". ;)
There are a lot of different quality products around. In my own personal opinion, I have experienced products from many different manufacurers and it is always clear that spending a little bit extra money avoids problems.
"Good kit" comes at a premium. But I would put into that list companies like "Linksys, D-Link, Netgear". These are companies who's main product line is based around networking products. They sell decent products with decent support. often they have developed the kit themselves in house. They also care about their customers as they want to see them come back again.
"Okay kit" then brings in companies like "Sitecom, SMC, Dynamode". These are cheap products which are normally repackaged generic Tiawanese kit. It normally works fine, but you need to be more of a tech to be able to get it setup. When you find good kit, your laughing. But the bad stuff is cheap enough to just chuck in the bin if it don't work. (I got lots of Dynamode 8-port Network Switches that work surprisingly well for £10:cool: )
"Cheap and Nasty Kit" brings in companies like "Belkin, Trust". Some of their products can be a totaly lottery of pot luck on the quality. Sometimes they work great, othertimes it is easier to setup the Cardboard Box to perform WiFi tasks than use their WiFi kit!! I have lost far toooo many hours to problems caused by these products. Belkin and Trust try and produce a cheap version of every device for computers, but none of these seem to be of decent quality. Always cheap.
"Unbranded/Rebadged" kit then brings up the rear. Included in here are those "one off" brands from companies who you have never heard of, and will never hear of again. Sometimes this kind of kit can be a gold mine of quality which is a bit techy to setup. Othertimes it can be of an even cheaper and nastier quality than Belkin stuff. Total hit and miss with lots of hassles.
All of the above kit will also need updated drivers and firmware at variosu times of it's life. This is also when you see how good the company behind it is when you try dealing with their support sites - especially for older products. :D
(Note - "Personal Opinion" means that other people will always have a different view. My view is based on 25 years of networking experience, with the last five of those fixing computer problems as part of my own business. Trawl these boards for other opinions and you will soon see common threads of the "good guys" and "bad guys" in hardware :))
I had the same problem with a linux box over wireless, I figured out the radio in the card was overheating and causing an improper hardware reset.
You do indeed, get what you pay for
A shorter answer - buy a D-Link or Linksys WiFi NIC from OCUK and try that out. If that works for you, sell or trash the old kcorp and call it a learning experience. :)
(BTW - I find it is very satisfying to smash the old duff components that caused hours of grief....:D)
the reason i got this card is that it is compatiable and easy to set up in linux as it uses the Ralink "RT2500" chipset.
Can you recoment a quality wifi card that is also supported i linux (ubuntu) please ?
