Hi,
A couple of bits of help needed.
I O/C my p4 4 months ago to:
Cpu: Intel Pentium 4 CPU 2.80GHz (Northwood)
Cpu Speed: 3.5GHZ
fsb:dram 5:4 (ddr 400)
corsair pc3200 1gb (512 dual channel)
MSI neo 2 mobo
memory voltage 2.6
meory timings (default) (2.4.4.4.8 as listed in cpu-z)
Vcore: 1.6
Cooling: Artic freezer 4
Room Temp: 23
Idle Temp: 36°C
Loaded Temp: 52 -56°C (48-50°C with case side off)
Ran prime 95 for 8hrs without error
Ive now changed my radeon 9800 pro for a 7600GT (agp)
Since this Ive started to get lockups in ww2 online, so I ran prime 95, which failed after 2 mins. The temps were about 60°C- 63
So Ive reduced my clock to 3.3 and Vcore to 1.575, this now runs prime for 8 hrs without error, temps about 60°C
So is this overheating (my old stock cooling ran the cpu at 70deg+)?
Or more worrying symptoms of sudden norwood death syndrome.
Or something else?
Cheers for your advice,
Edit: just ran 3D 05 and got a higher mark, using 92.91 driver though.
Cpu Speed: 3.5GHZ
MSI neo 2 mobo
memory voltage 2.6
Vcore: 1.6
Room Temp: 23
Idle Temp: 36°C
Or something else?
