Lost 24 pin Seasonic cable
In theory that "should" work.
The only potential issue is if Seasonic used an exotic pin layout for their 18pin (2x9) and 10pin (2x5) layout on the PSU side (I don't think they would do that). This cable also has inline caps, which the one you linked also has, so it should be good to go; again, assuming no alterations from the usual pinouts were deployed on the PSU side.
Never, ever use cables not designed for use with a psu. The Corsair psu's that cable is for are built by CWT and Great Wall and will have different pinouts to the Seasonic. Using a incorrect cable can easily kill the psu and potentially anything connected to it. Your best bet is to contact Seasonic directly.
