Lost a tooth!
18 Mar 2006
Liverpool
Well, planning on it anyway..
Looking at getting a new front sprocket, so I can drop 1 tooth, just for that bit extra acceleration and fun and what not.
Now' I've not 'long' replaced the entire drive train, was about 3K miles ago. Will I be OK to carry on using the current chain and rear sprocket? Or would I be best to replace the entire thing again, and maybe keep the current one as spare or what? I know they always say replace as an entire set, but as this more of a modification rather than maintenance, I'm hoping I'll be OK?
When I did the R1, I used the old chain and rear sprocket with ~12K in them and they were fine, just needed to wind the blocks out a bit more.
A friend told me that if you got -1 on the front you can use the existing chain, but if you +2 the rear, it's new chain time; extra links needed I guess - could be wrong with my recollection.
no you are right mate
Went for -2 in the end, just for the extra bit of craziness lol, should be OK with my current chain according to the guys in the shop. Will see how I find it, if I find it too much, and feel that I've lost too much top end, I may drop down to a -1, and possibly look at getting a +2 at the rear as well..
Just had to fork out and get loads of tools too, a nice big Torque Wrench, 32mm and 36mm sockets, and a paddock stand :D. Pay day is awesome.
What bike is this on?
I've got a 16t front sprocket ready to go on my RSV-R, standard is 17t. Will be using the existing chain and sprockets (<2k miles old).
