Lost desktop background
5 Apr 2006
I did a Search & Distroy spyware scan the other day, and one of the suggested "fixes" said something about removing Active Desktop. Like the muppet I am I clicked yes and am now without a desktop background picture.
Does anyone have an idea how to reverse this? If I try to select a picture it's simply not added as a background.
System restore. Ususally solves all my problems :D
System restore. Usually solves all my problems :D
Have you scanned your system with any other Adaware/Spyware cleaners? Maybe worth a try..
What do you currently have as your background? Just a single colour?
Within Spybot S&D it creates Registry back-ups.. Was one of the fixes to your 'active desktop' editing a registry key? If so maybe try recovering the original registry values etc..
The thing is I have no spyware; I've done scans with different pieces of software and they all confirm this. The active desktop bit that was removed by Search & Destroy is, I think, a pure Windows thing and I've seen it being listed in Search & Destroy scans on both this and other PCs before.
The thing is that this time I was trying to be clever and pressed "delete" whereas before I just ignored it. I've undone the Active Desktop removal in Search & Destroy and also followed your tips above but it makes no difference - still no desktop background. Any other ideas or do I just wait until the next reformat?
