Lost my overclock manual
22 Mar 2009
Can you guys help me what is the correct setting on Gigabyte EX58 UD5 motherboard bios for 4.00Ghz and 4.20Ghz for overclock. My warranty with overclock bundles had now ended. :( So, I don't think Rich can help me further now but maybe he will if I ask him nicely.
I should have stored manual settings in my folder (penflash)
I am currently using 2.67Ghz stock speed at the moment as my ocuk profile had disappear from the bios after updated latest firmware version. I can't find my penflash (overclock bundle on it) must have lost it. :(
For the amount you have overclocked i'm suprised you can't remember the settings yourself, I can still remember the overclock I had set for my Q9650 @ 4.4ghz :p
Oh dear bulldog
4GHz:
Vcore: 1.30
Dram Vcore: 1.64
PCI express freq: 101
Dram multiplier: 8 (to give you 1603)
BCLK: 200
Multiplier: 20x
Memory timing: 9-9-9-28-2
CPU differential amplitude: 900mv
PCI differential amplitude: 800mv
For 4.2 adjust accordingly
Oh dear bulldog
4GHz:
Vcore: 1.30
Dram Vcore: 1.64
BCLK: 200
Multiplier: 20x
Many thanks for this, but can you give other setting for the one with 191x21 something like that ? and vcore 1.30v is seem too high (leads temperature to 85C) or was it to do with most stable one ?
If it is stable at 1.30 vcore just lower the vcore gradually until it isnt stable and then put it back up a notch then you have found your lowest vcore.
The memory ram 8x multiplier at 1604mhz isn't showing anymore, it only show as 1600mhz (4mhz extra are gone ?)
are these ok ? was it cause to end up BSD ?
I did the same setting what NathWraith told me of bios setting. I had done 20x21622 linx as it error after 5 runs, try Occt got error after 7 mins, try prime95 blend got 6 cores running but 2 other cores stop running, stopping working on cores 3 and cores 6.
It used to be stable before (24 hours on prime95 last winter) but now it failed with BSD after prime95 3 hours!
I think I might know now of why my overclock bundles isn't stable as before. Because of different bios firmware version as I did updated to bios firmware F12 but I think I brought the ocuk bundles last time was F7 bios ? I can't remember which bios version could be F7 or F9. I think Rich might know which bios version does work on my overclock stable.
I had now finally stable my pc after 14 hours prime95 blend test with 191x21 with 4Ghz. It took me almost 3 hours to get it right setting without cause any BSD.
Here is my stable 4Ghz overclock using F12 (firmware in bios):
Linx stable:
ITB stable:
Prime95 blend stable after 14 hours:
OCCT stable:
4Ghz setting in Bios:
Intel(R) Turbo Boost Tech Enabled
Cpu Clock 21x
Cpu Frequency 4.01Ghz (191 x 21)
Qpi Clock Ratio x36 (6.87Ghz)
Uncore Clock Ratio x17 (3247Mhz)
Qpi Link 6.87Ghz
Base Clock Enabled
BCLK Frequency 191
Advanced
Base Clock Enabled
BCLK Frequency 191
PCI Express Frequency Mhz 101
C.I.A.2 Disabled
Cpu Clock Drive 900mv
PCI Express Clock Drive 800mv
Cpu Clock Skew 0ps
IOH Clock Skew 0ps
Performance Enhance Turbo
System Memory Multiplier 8.0 (1528Mhz)
Dram Timing Manual (Expert)
Memory Settings (Triple Channels)
Cas 8
TRCD 8
TRP 8
TRAS 24
CMD 1T
Cas 8
TRCD 8
TRP 8
TRAS 24
CMD 1T
Cas 8
TRCD 8
TRP 8
TRAS 24
CMD 1T
Load line Calibration Disabled
Cpu Vcore 1.27500v
QPI/VTT Volt 1.200v
IOH Core Volt 1.140v
DRAM Volt 1.650v
Cpu PLL 1.800v
PCIE 1.500v
QPI PLL 1.100v
IOH Core 1.140v
ICH I/O 1.500v
ICH Core 1.100v
The rest as Auto
Done my 4.20Ghz stable:
and my F12 4.20Ghz setting at the bios are:
4.2Ghz overclock F12 bios.
CPU Clock Ratio – 21x
Advanced CPU Features:-
CPU Clock Ratio - 21x
Intel (R) Turbo Boost Tech. - Enabled
CPU Cores Enabled - All
CPU Multi-Threading - Enabled
CPU Enhanced Halt (C1E) - Enabled
C3/C6/C7 State Support - Disabled
CPU Thermal Monitor - Enabled
CPU EIST Function - Enabled
Virtualization Technology - Enabled
Bi-Directional PROCHOT - Enabled
QPI Link Speed - x36 (7.2)
Uncore & QPI Features:-
Uncore Frequency - x19 (3800Mhz)
Isochronous Support - Enabled
Base Clock (BCLK) Control - Enabled
BCLK Frequency (Mhz) - 200
Advanced Clock Control:-
PCI Express Frequency (Mhz) - 101
C.I.A.2 - Disabled
CPU Clock Drive - 800mv
PCI Express Clock Drive - 900mv
CPU Clock Skew - 0ps
IOH Clock Skew - 0ps
Performance Enhance - Turbo
Extreme Memory Profile (X.M.P.) - Disabled
System Memory Multiplier (SPD) - 8.0 1600Mhz
DRAM Timing Schedule (SPD) - [Expert]
**The following 5 options need setting for each stick of ram and are dependant on your ram**
CAS Latency Time - 8
tRCD - 8
tRP - 8
tRAS - 24
Command Rate (CMD) - 1
Advanced DRAM Features:-
I haven’t changed any of the sub settings in here
Load-Line Calibration - Enabled
CPU Vcore - 1.30000v
QPI/Vtt Voltage - 1.32000v
IOH Core - 1.12000v
DRAM Voltage - 1.66000v
Advanced Voltage Control:-
CPU PLL - 1.84000v
PCIE - 1.5000v
QPI PLL - 1.14000v
IOH Core - 1.12000v
ICH I/O - 1.50000v
ICH Core - 1.14000v
**Rest of settings in here on Auto**
good times
thats some pretty good clocking BD
i knew you had it in you :p
its good to see you tested using a range of stress tools
no point just testing linpack if you get blue screen death in other things!
lovely stuff, my C0 is not quite up to the job. with the 4GHz settings BSOD on windows splash screen, with Vcore = 1.3V BSOD instananeously when starting a Prime95 blend!
woah woah
if you are using a C0 chip you may want to tone it down a bit
maybe try 181X20
then maybe look at starting your voltage around 1.38v
then work down from there until you get low voltage.
some C0 chips do 4GHz+
mine did 4.2 on air so it is possible, you just tend to need more votlage for them as a rule of thumb :)
:) no worries! yeah knocked it down to 181x and going again. Besides disabling hyperthreading and reducing Vcore, are there any other settings in the BIOS that are effective at reducing temps?
good times
Many thanks Rich :) I had now got 2 x Akasa Viper fans (1900rpm) in a push-pull and add another 1 x Akasa Viper fan at the rear exhaust as three fans is control with PWM with a special cable 'Akasa AK-CB002 PWM Fan Splitter Cable' from ocuk as it was silent when using overclocking. And during overclocking, the max temp for 4.2Ghz @ 1.30vcore (bios) is 77C, 74C, 76C, 73C and I am very happy with it overall.
I love this fans: http://www.overclockers.co.uk/showproduct.php?prodid=FG-059-AK as I did order it last week.
I can't wait to get my hand on i7 970 (6 cores / 12 threads) in 2012.
