lost my overclock!
18 Feb 2010
Hi, I have a Titan 8300i Supersaurus MK II" Intel Core i5 2500K 3.30GHz @
4.60GHz DDR3 Quad Core System but on boot up it lost its settings and went back to the default one.
its using a Gigabyte Z77X-UD3H Motherboard.
I followed the instructions to get back the overclock. press DEL, go to save/exit and choose profile 1
but it tells me that profile 1 doesn't exist!
So what settings do I need to get the overclock back please?
Thankyou
Chris
If I remember reading a thread a while ago, post in the CS section, I believe they "Might" have the settings they used saved.
I could be wrong, or you could use this for a chance to learn how to overclock, very easy on the z77 platform, lot of people here can offer great advice.
I had that exact same board and CPU, all I had was issues with the my overclocks being wiped. I tried all sorts of BIOS versions and different things but always had issues with that board.
That was a around 18months ago or so.
I never manage to sort it and ended up upgrading anyway, board is still in my loft.
What version of BIOS are you using and how long have you had the system? Hopefully it's still under warranty and Ocuk can help.
