Lost Planet Problems
31 May 2007
London
Rig:
E6600 3.0
2gb ram
BFG 640mb 8800 gts (forceware : 158.43)
Vista 32bit
I installed lost planet and tried to load dx10 version and all i get is a blank screen. I can hear all the music and sounds if i try to go up an down on the menu but the screen just remains black.
Any idea why this is happening?
Thanks
Edit: was meant to post in pc games section..
Ahh found out what problem was.
The resolution was set at very low for some reason i just edited the settings using notepads and changed it to 1024x768 :)
helmutcheese said:
Well you obv dont have that right now LOL. :p
The newer beta are for Lost Planet, they fix a bug in last Betas that were pulled that caused ontrol Panel to crash with Ntune nothing really bad if you dont use Ntune. :)
http://www.nvidia.com/object/winxp_2k_162.18.html (Xp/200only), I gather Vista ones will follow as they were all up before pulled last week.
I indeed use ntune game was fine when i played it now using drivers i had from before.
