Lost WU
9 Feb 2009
Sunny Fife
Hi,
I normally leave my rig on during the day when I'm out at work, I have it uploading to my web space so I can check how things are doing.....pretty sad eh.
Yesterday I noticed that it finished one WU but never started another all day, when I got home it was stuck trying to upload the finished WU. I stopped the program running & restarted it (I'm using FAH GPU tracker V2), when it fired up it was back to 0% & the WU it had finished was gone.
Is this something that happens a lot or something I can avoid in any way?
I know it's only 1 WU but that is around 8 hours for me lol.
It might be worth checking that you haven't got the "one unit" option ticked in the tracker config, when you have this checked it will complete the unit then stop until told to start again (and it just sits on 100% even though it has uploaded it) then if you restart the tracker it starts again.
Nah it was stuck trying to upload it, I looked at the cmd box (I think that's what it was) that was running & it had a whole pile of retries.
Ok just checked my home PC with HFM& it has "SendingWorkPacket" on it, this is where it hung on the last WU so it looks like I have a problem.
The log shows that it is failing to connect :-
[11:31:58] Finished Work Unit:
[11:31:58] - Reading up to 3701664 from "work/wudata_02.trr": Read 3701664
[11:31:58] trr file hash check passed.
[11:31:58] edr file hash check passed.
[11:31:58] logfile size: 67893
[11:31:58] Leaving Run
[11:32:01] - Writing 3804493 bytes of core data to disk...
[11:32:02] Done: 3803981 -> 3523419 (compressed to 92.6 percent)
[11:32:02] ... Done.
[11:32:02] - Shutting down core
[11:32:02]
[11:32:02] Folding@home Core Shutdown: FINISHED_UNIT
[11:32:06] CoreStatus = 64 (100)
[11:32:06] Sending work to server
[11:32:06] Project: 6963 (Run 0, Clone 17, Gen 74)
[11:32:06] + Attempting to send results [May 11 11:32:06 UTC]
[11:32:29] + Results successfully sent
[11:32:29] Thank you for your contribution to Folding@Home.
[11:32:29] + Number of Units Completed: 21
[11:32:33] Project: 6056 (Run 0, Clone 80, Gen 322)
[11:32:33] + Attempting to send results [May 11 11:32:33 UTC]
[11:32:35] - Couldn't send HTTP request to server
[11:32:35] + Could not connect to Work Server (results)
[11:32:35] (171.64.65.54:8080)
[11:32:35] + Retrying using alternative port
[11:32:36] - Couldn't send HTTP request to server
[11:32:36] + Could not connect to Work Server (results)
[11:32:36] (171.64.65.54:80)
[11:32:36] - Error: Could not transmit unit 01 (completed May 10) to work server.
[11:32:36] + Attempting to send results [May 11 11:32:36 UTC]
[11:32:38] - Couldn't send HTTP request to server
[11:32:38] + Could not connect to Work Server (results)
[11:32:38] (171.67.108.25:8080)
[11:32:38] + Retrying using alternative port
[11:32:39] - Couldn't send HTTP request to server
[11:32:39] + Could not connect to Work Server (results)
[11:32:39] (171.67.108.25:80)
[11:32:39] Could not transmit unit 01 to Collection server; keeping in queue.
[11:33:09] Project: 6056 (Run 0, Clone 80, Gen 322)
It pretty much just repeats that. I now have 21 WU's completed rather than 20 so it must have sent that one, is the problem in sending or receiving another. My home network seems fine as it is uploading the webpage I use to check the client from.
Help please, I am as ever CONFUSED.
