Lotro and SLI/crossfire
Caporegime
18 Oct 2002
Seems to be a stupidly hard question to answer it seems. is anyone actually running either Sli or Crossfire, does the game get a boost in speed. its a tad slow at 1920x1200 and dx10 + super high everything, recently since going to the 24" screen i've dropped down settings to keep it as smooth as possible.
Thinking of going the 2x3870 route but, their forums are useless in terms of saying of crossfire/sli offer speed improvements or not.
Likewise, it seems completely ridiculous that neither ATi or Nvidia, from what i can tell, offer a list of games and a maybe guesstimate of what performance boost you get with games. Surely both companies want to sell sli/crossfire as it means two sales instead of one. they obviously test out almost all games for driver bugs and issues, both companies have to know which games work and which ones offer between slight and massive performance increases, is it that big a step to take that knowledge and stick it on a page on their sites?
I'm not a huge fan of nvidia, but seeing as its my main game at the mo i guess i could switch back, vista 64 bit drivers have been shocking every time i use nvidia for the past year though, so not massively keen on it.
Having a look at nvidia site just now, you can find a list of lots of games that work with sli, but no indication in the slightest of what performance benefit there is, which is the key info.
Need a list for instance say for crossfire that said, hl2 +30% performance, Lotro + 10%, Crysis + 2%, Cod4 +60%, UT3 +4%. along those lines, for most games, in which case if you only play crysis, lotro, ut3, it won't help you. if you mostly play cod4 and hl2, it could give you a pretty big boost.
But my main issue here is nothing anywhere seems to say if lotro gets a boost from sli or crossfire.
I am running lotro in crossfire, you have to ensure that you are not running the game in windowed mode for it to utilise both graphics cards. I also heard that you have to have DX10 enabled.
This however poses a huge problem for me as I run dual monitors and to be able to use both monitors you have to have the game windowed - ridiculous :mad:
Since going to crossfire I am unable to see a boost myself
LOTRO isn't so demanding as to require sli or crossfire to run on max though, I think I'd spend more on a single powerful card. I'm only using an 8800GTS 320MB and I've got everything maxed cept the AA (2x) and the af (2).
When I eventually upgrade to a 4870 I expect to be able to push those up too. If you really have to crossfile it you're probably best going for 2 x 4850's. Just over £ 200.
well i moved from 8800gtx to a G280 recently and i only play MPvP in lotro, if you want to test how good the performance is visit the Ettenmoors when theres maybe 2 creep v 2 freep raids battling it out ...
the GTX would be so crippled i would have to turn (nearly) all settings down to medium(dx9) to get maybe a framerate of 8-14fps during such big battles, now with the G280 i can get away with dx10 and everything turned up to Ultra and achieve the same framerate ...
ok this isnt directly helping your question about sli/crossfire, but its the first game ive seen such a massive improvement justifying the purchase of the G280 and it would be interesting to see what sli could achieve..
