LOTRO quest tracker?
15 Nov 2007
When i was playing WOW i remember installing a quest tracker that showed you where to go on your minimap,is there anything like that for lotro?i've googled it but can't seem to find anything,thanks:)
nope, your out of luck, best thing you can do is look up a quest guide, they are not hard to come across, unless your playing the new MoM content
Nope, took a bit of getting used to again after having played WAR, makes you go and actually read the quests :)
yep, to me its much better, War is simply to easy and frankly boring in regards to the quests, i never read one after the first hours play because it was entirely pointless. Lotro i tend to read some/most unless its an easy goal, there are normally semi accurate clues, though the odd quest is an absolute joke in how utterly vague even the goal is let alone finding it. But I think other than making questing more interesting, when you get hard quests the community is there to help, and you to help others if you happen to come across location of something obscure. SAme happens in quite a lot of MMO's, War, theres zero talking because theres no help needed at any stage.
