- 18 Nov 2008
Ive just built my first system, everything seems to be up and running, but when installing almost all programs/games etc from dvd im getting lots of crc and general data errors, forcing me to quit the install. Very annoying
My system is:
Asus p5qe
Ati 4870
E8400 duo
4x1gb ram OCZ
Vista 32 bit
Samsung f1 500gb hdd
Sony DRU 190a
Antec 900
Have installed bios update. Have installed windows updates etc
Could this be due to my 4 x ram?
Thanks in advance
Darren
Update 27th Nov
Guys I've checked the ram, changed the hdd, changed the dvd drive, changed all the data cables, so I thought it couuld only be 1 thing...the motherboard.
Bought new motherboard, fitted it last night, fitted everthing to it, installed vista 64 this time...........same problem while installing wow got to around 24% and threw up that same error msg "windows can not verify the content at C:\programfiles(x86)\worldofwarcraft\common.dat (or something along those lines), this could be a problem with your system or a problem with the drive at C:\"
What could be causing this? I really am out of ideas now
Update 28th Nov
SOLVED
Took all memory out and just left 1 x 1 gb stick in, installed my game no problem.....shame i didnt try this before i spent 300+ quid on replacement parts!
No worries tho because my mate wants to buy all spares for his 1st build.
Only problem i have now is I cant increase the ram over 1gb or the problem returns. I will put a post in the memory section so if anyone could help me set up the bios timings etc, please post in the memory post im about to make.
Thanks
My system is:
Asus p5qe
Ati 4870
E8400 duo
4x1gb ram OCZ
Vista 32 bit
Sony DRU 190a
Antec 900
Thanks in advance
Darren
Update 27th Nov
Update 28th Nov
SOLVED
Thanks
