Lots of errors on Memtest
12 Dec 2005
In my other PC I've been getting GPU errors with the driver stopping and then restarting so I decided to first memtest the ram in my PC.
RAM is 2 x 4GB
The first 2 minutes of memtest found many errors and after about 30 mins their was a total of 180+ errors.
I took one of the sticks out and tested individually, one of the sticks was fine. Replaced it with the other stick and within a couple of minutes their were errors again, tried the stick that had the errors in the other RAM slots and had the errors so it confirms it isn't a problem with my mobo.
This definitely confirms an issue with the RAM? I wasn't aware RAM could cause a GPU driver to crash though.....
Which ram and motherboard?
I had some ocz ram that needed 2.1 volts to be stable (said so on the ram), mobo default was 1.8. On default settings I would get memtest errors.
Very true, although his other stick appears to be working fine with his default voltages. Worth a look though.
