Lots of hard drive space!
2 May 2004
Hi,
Currently I have 3 drives in my case, but would like to put a further 2 in, and maybe more in the future.
I've been looking at both the Coolermaster CM690 II Advanced and the HAF 912 as they both have 7 3.5" slots, and a few 5.25"s that can be converted if necessary.
Are there any other cases out there that have so many 3.5" slots? What are my options? :)
Thanks.
Hmmm looking good! The XL is a bit big in terms of height and depth, it would be a bit out of place under my desk I think, however the R3 is almost exactly the same dimensions as my Lian Li PC-7.
I'll have a look at some more pictures and reviews of the R3, looks like a very nice case! Only thing I'd miss out on is the SATA dock that the CM690 has on top. Saying that though, you can buy nice USB ones cheap these days which would mean I don't have to use that additional SATA slot internally.
Thanks
Craig
good choice you can always turn the top 5.25 bays into hd bays with a converter if you need more hd space
Yep, it comes with one converter as well :)
I'll only be using 3 to start with as I've decided to get an enclosure for one of my other drives as it'll be used for backups, but I'll definitely be needing more fairly soon. 8 slots should be adequate for now :D
From my post in the R3 thread:
In need of more hard disk space (I previously had an Antec 300 and had maxed out the capacity), I picked up an R3 last Thursday from OcUK. I'm very pleased with it - build quality is great and it's so much quiter than the Antec 300. I'd recommend it.
Bonus points: looks better than the 300, cable management is better, and the CPU cut out would have been handy when I first fitted the H50.
Very nice. You have a lot of drives, what setup are you running there, or is it just a ton of storage?!
Still trying to sort out building a second PC out of my spare E6600 and 4GB RAM I have, I was planning on using my current PC-7 for that and buying the Fractal as my new case, but I haven't been able to source a decent motherboard yet.
Might just go for it anyway and put the PC-7 to one side for now. Such a nice case, and will allow me to make use of spare my 500GB drives at last!
