- 26 Nov 2006
Currently have a 3200+ venice, 1gb corsair ram, AMD A8V mobo, radeon 9550.
Tried overclocking it but failed miserably due to the mobo.
was told to buy a MSI K8N Neo2 platinum, but no real success.
However I just bought this for 120
AMD Athlon 3000+
Motherboard MSI K8N Neo2 Platinum (USED) + Drivers + Manual
NEW OEM AMD Atlon 64 939 socket
1GB DDR 400 Memory 2*512mb (Just Few Hours Of Use)
Geforce FX5200 AGP 8X 128MB (USED)
x1 IDE Cable (NEW)
x1 SATA Silicon Cable (NEW)
x1 SATA Power Cable (NEW)
PSU 500W (USED)
Motherboard Conectores metal plaque for case.
First of all, was it worth it?
Secondly, Im planning on taking this new mobo and putting the gig of corsair RAM i have at the moment in it, is this possible? I assumed that because they are both 939 it was.
Also plan on putting the 3200+ venice processor onto the mobo and maybe the graphics card if the radeon 9550 is better than the geforce fx5200
If this is possible I will be taking pictures once recieved and hopefully get some help on how to arrange things, First time doing anything with hardware.
Oh and there is no heatsink on the 3000+ processor, I figured that doesn't matter if im putting the 3200+ in?
Thanks a lot, im kinda excited with this, hope it works and hope i wasn't ripped off
AMD Athlon 3000+
x1 IDE Cable (NEW)
PSU 500W (USED)
