Hey everyone - first time post from a long time lurker, and I'm afraid it's going to be long
I've been looking for a while now at switching from air to watercooling for a bit of an unusual reason - noise. I've never touched watercooling before and all I have to go on are a bunch of forum posts which have been helpful. However I still have a fair few questions so I'll just write down as much as I can here and hopefully someone can tell me where I'm right and wrong.
Firstly here's the stuff I have now:
Q6600 at 3.33 GHz on a Thermalright 120 Ultra Extreme with a Noctua fan at 800 rpm (not sure how many volts that is)
4GB 800MHz mem
8800 GTX w/ stock cooler, not overclocked
WD Raptor 150 + 500 GB samsung storage drive
Seasonic 600w PSU
Intel P35 MB (asus P5K-E)
Couple of very quiet case fans (top and back)
and all the other things that don't matter much to cooling or noise
inside an Antec P180B.
Temps - CPU 40-45 idle, 65 ish load
GPU 65 idle, 88+ load
Now this system is obviously pretty quiet at idle, but what's really started to get to me is the noise of the 8800 GTX fan under load. From what I've read of GT200 / RV770 reviews, the stock coolers on all of them are even worse. I know there's a few aftermarket aircoolers I could try but I think I'm looking for a more long term solution now. I don't mind spending quite a bit of money to do it right if that's what it takes. (I do enjoy messing with this kind of thing after all). Specific things I'm wondering about are below, any help is greatly appreciated.
1: How quiet is it possible to make a top-class watercooling setup, compared to the aircooled spec above? I'm sure that at idle it'll be louder, but it should be quieter under load?
2: Assuming I watercool both the CPU and the GPU in one loop, what kind of radiator would people recommend to do the job and preferably give temps equal to or lower than the aircooled setup? Would a 120.2 do or would a 120.3 be better - I'm assuming the extra 120mm fan wouldn't add too much to the noise level, and I'm not too bothered about the extra cost.
3: How fast do the fans on the radiator have to spin to do the job properly? I think I read somewhere that if the fans spin too slowly, the air doesn't get through the radiator properly and the cooling becomes useless - but I can't remember where I read it. Does anyone recommend any particular fans to be used there where noise is a priority?
4: stupid one but I'm still not sure - do you generally attach fans only to one side of the radiator, or to both?
5: the blocks I'd need are for CPU and GPU (I think
). Not too worried about the CPU block, I can research that one more later. With GC blocks though, the general impression I get around here is that the full coverage blocks are a little overpriced and obviously have to be replaced with a new card. Would a core-only block do the trick for the 8800 GTX and potential upgrades?
6: Case - I know the P180 would have to go, even though I like it, because it's so small. Trouble is, I'm so rubbish at DIY that if I started drilling holes in any case it would all go wrong very quickly and I'd be left with a pile of metal shards or something. On that note, are there any cases in which all these things can be mounted without any need for drilling (Pretty sure the answer to this is no, sadly, but I thought I'd check anyway)
7: If I ever ended up with a nVidia MB again, I'd want to watercool the chipset to get rid of that awful fan they put on there - the one on the 680i drove me crazy. Would the loop be able to handle this additional without too much difficulty? And am I right in thinking there's not a lot of need with the passive P35?
8: Pumps - as with CPU blocks I'm not too worried as I can do more research if I decide to go with it but if anyone has any recommendations for a quiet one, I'd like to hear them.
Think that's everything, any help or suggestions would be great.
Mark
4GB 800MHz mem
Seasonic 600w PSU
Mark
