Loud cooling- Fan controller
27 Jun 2013
London,England
Long story
So recently I bought a Bitfenix Ronin case and a Corsair Hydro H105 both from Overclockers obviously. But am having a problem with noise, the mixture of loud 140mm fans and a case with perforated holes in the top is making it sound like a jet engine!
Long story short
Im looking for a recommendation for a fan controller that preferably takes up only one drive bay and had an LCD touch screen.
My case fans are
2X 120mm Spectre fans (Came with the Ronin case)
2X SP120L high performance Corsair fans (Came with the H105)
I would have loved the Bitfenix recon or Nzxt Sentry 2 but due to bad reviews I am no longer considering these.
PS: Im not rich :)
Thanks James ;)
Pricey but exactly what I am after looks wise, I presume this can be used to switch the fans of completely ?
Thanks for the reply, I may have to just shell out for the quality :)
On a different point, which motherboard and RAM do you have in your system?
I'm looking at doing a client build with a H105 in the Bitfenix Ronin, and I'm not sure about motherboard compatibility given how much the H100i overlaps the RAM slots in a Ronin, let alone the H105. I'm already planning standard or low-profile RAM, but mindful of heatsinks on the motherboard.
But if you've done it I'd love to know what your board and RAM is, and a pic if you can :D
Cheers.
