Hi, so, here is my rig:
Case TW00193 Coolermaster MasterBox MB530P
Motherboard MB00311 Asus TUF Gaming X570-Plus Wifi
Power Supply PS00102 Corsair 750W TX750M 80+ Gold
CPU CP00275 AMD Ryzen 9 3900X
CPU Fan beQuiet! Dark Rock Slim CPU Cooler - 120 mm
Graphics card GC00150 Geforce RTX 2080Ti 11Gb
The beQuiet was just added yesterday after my effort to reduce noise level. However, it had no effect at all, as if it had never been the CPU or so.
Honestly, I can't tell where the loud fan comes from.
Sitting diagonally from my PC, my ears at least 2 ft. 9in. (~84 cm) from the top of the case, the noise level reaches on avg. 41.8 db (measured with my phone, no expert here).
Should this level be expected from that config?
I tried:
1) playing about with SpeedFan but a bit reluctant to leave permanent config since I am no expert and no real success anyway.
2) BIOS Silent set-up for the Dark Rock Slim (decreased from full speed 1500 RPM to 600-700 RPM)
3) physically gently pushing one finger in the center of most fans without being able to understand where the sound comes from.
I think it is sourced from the bottom side of the case, either the PSU or the 2080...any ideas?
I tried:
