Hi all,
Looking for some advice on the amount of noise my fans make. I'm wondering if it is normal or not.
So my current specs are:
Asus Z97i-Plus
i5 4690K (Devils Canyon)
H80i Cooler
KFA2 920 OC Silent “Infin8 Black Edition”
BitFenix Prodigy Mini ITX Cube Case
PSU: SuperFlower Golden Green HX 550w
Once I turn the computer on the fans start up with it, they are quite loud. I presume this is just a test the computer runs, the fans calm down shortly after. When I start gaming however, no matter what game I seem to play the fans kick in and they really loud (I am not overly bothered because I wear a HS but I am sure it can get annoying for those around me).
I understand that my case probably doesn't do much to dampen the noise but is this completely normal? Is there a safe way to reduce the amount of noise those fans make without putting the components at risk of damage from over heating? i.e get the fans to only kick in at a certain temperature, what are the implications of doing so?
Asus Z97i-Plus
H80i Cooler
