Hi all,
I've got a Liang DDC pump in my watercooling loop.
The loop goes like this: Res -> Pump -> GPU -> CPU -> Rad -> Res.
Like this:
It makes an annoying buzzing sound, that's by far and away the loudest thing in the case.
It has the XSPC clear top on it, and I've already tried loosening the screws slightly, which didn't make any difference.
It's mounted on foam pads, and holding it (and anything else that might vibrate) makes no difference either.
Reading around, it appears that the only other thing it might be is that the flow rate is too high, so everything is spinning fast and making a racket.
Components list:
CPU: Alphacool NexXos Highflow AM2
GPU: EK Waterblocks GTX470
Res: Danger Den Rad (which, incidentally, I wouldn't recommend)
Rad: Thermochill 120.3
Pump: Liang DDC 18W
If they are just 'naturally loud', then what would people suggest as good alternatives, considering I may add another GTX470 to the loop later, and the pump needs to retain its current position (so the replacement would need a vertical intake and horizontal outflow).
Thanks
Like this:
Components list:
Pump: Liang DDC 18W
Thanks
