Loudest GPU fan in history!
Suspended
4 Apr 2007
check out the Sparkle 7600GT 256mb :|... Jesus christ!... sounds like a REALLY high pitched and loud "Hiss"/Vaccum cleaner. Horrible sound. Overpowers everything else in my old pc put together
Slogan said:
Speaking of loud fans, my X1900XT's fan is really getting me down.
Yup even on idle it makes a droaning sound (mate has X1800XT in a HTPC so obvious what is making the racket) Even on a gaming rig noise is annoying when it speeds up/down during a game. Replace the stock cooler.
My stock 1800xt fan was ridiculous, sounded like a jet turbine starting up. Get a Zalman VF-900, problem sorted. :)
Slogan said:
I would do, but I'll be upgrading shortly anyway - so there would be no real benefit. Maybe get a few more quid for it on re-sale, but nothing amazing.
Same here tbh. Its 10:20 now.... my 8800GTX should be here in a few mins :P
I had a fx 5800 ultra, got it cheap and after a few weeks with it I had to get something else - sold it to a polish guy at work though, they will buy anything!!
loudest thing i ever heard coming from a PC was someone in my college made a custom GPU cooler with a motor from a powertool 24,000RPM 120mm fan :D it was like a leafblower ;)
Jeeez... must have been cool! lol.... Ive seen a mod where a guy has taken a Dremel engine... and put a 200mm fan on it... not sure what RPM dremmels spin upto tho? :p
lol only worked for about a minute until 120mm fan-a-la sushi, the fan just disintergrated, you can do it with a dremel and CDs, dremels spin obserdly fast, like 25,000RPM or something, stick a CD on the end of one and it just explodes :D
*runs around screaming with a shard of CD sticking out of his eye*
