Low 7950 score
30 Dec 2011
Essex
Hey guys,
I have run the unigine heaven benchmark on extreme to find a really low score of 780. I OC'ed it to 1100 core clock and 1500 memory clock with no fan or voltage adjustments. My CPU is also newly clocked at 4.5GHz with 1.3v. I was receiving temps of below 60 during the test. However I have installed logmein a remote access program which may be interrupting my FPS. When I got my score it said it was running of a logmein mirror driver. Would this make a difference?
CPU OC: Just want to know of any improvements I could make to it such as disable spread spectrum and other settings.
EDIT: Also about graphics after installing AMD catalyst suite I saw a huge downgrade in image quality in the desktop probably because I run it on a TV instead of a monitor (scaling). How can I fix this?
Thanks.
