Ok I did this and the highest temp I saw was 68C, so you are right it is the air flow. Should I just buy a new case, I've had this one since 2013.Open your side panel and play bf
Depends on how much you willing to spend. My recomendations for airflow cases (that are also pretty good in all aspects) are the be quiet 500dx (though doesn't come with lots of fans, you need to buy some yourself), the lancool 2 mesh or the newly released lancool 3, and the fractal torrent (either the mid or the full tower one). The last one is pretty expensive but it comes fully equipped with fans everywhere (except an outtake on the back which you don't need). Youll see a huge difference in your temps with all these options.Ok I did this and the highest temp I saw was 68C, so you are right it is the air flow. Should I just buy a new case, I've had this one since 2013.
ba dum tss!I wouldn't worry to much about temps, it's the summer right now so a worse case scenario.
Yeah I couldn't figure out how to do it, another good thing about a new case is that it would run a lot quieter, this thing sounds like a hovercraft when it struggles to keep my system cool. I put the side panel back on and it hit 80C once in BF 2042, with the side panel off it hit 70C once but mostly around low 60s.Just seen people in the comments saying it needs to be modified to install lots of intake fans at the front.
Well I’ve gone ahead and ordered a Fractal Design Torrent Black Dark Tint Windowed PC Gaming Case. My old case was over 9 years old and still had spaces for internal Blu-Ray drives. I use an external one.
Exactly! worse case scenario low 80s perfectly acceptable in the summer heat.I wouldn't worry to much about temps, it's the summer right now so a worse case scenario.
I’ve got an air flow problem, maybe you don’t but I am seeing higher CPU temps than I should while gaming. Running CPU tests like Cinebench doesn’t affect it as it’s the heat being dumped into the case by the GPU at the same time which is not being effectively dealt with by the cases cooling system.Don't concern yourself about it OP.
I am exactly the same with a case not ideal for my 3070 card. It will be cooler when the heat goes. Low 80s in this heat is fine . I hit 77-78 when I game and that's with a dark rock but only in the 60s when I peg the cpu 100 % on cinebench.I’ve got an air flow problem, maybe you don’t but I am seeing higher CPU temps than I should while gaming. Running CPU tests like Cinebench doesn’t affect it as it’s the heat being dumped into the case by the GPU at the same time which is not being effectively dealt with by the cases cooling system.
It’s cooler when I take the side panel off the case or blow air into the front of the case with a desktop fan which shows it’s not just the summer heat.I am exactly the same. It will be cooler when the heat goes.
yes that's right! But low 80s is fine! it'll be lower in the winter.It’s cooler when I take the side panel off the case or blow air into the front of the case with a desktop fan which shows it’s not just the summer heat.
