Hi, my dad has asked me to get him a new pc... The current one he is using is very old and painfully slow, so its time to change. I'm after something around the 400-450 pound mark but which i know is a tight budget
Things required:
-Screen
-All the components for the tower (including case)
-Not a speaker/mouse/keyboard
-No OS or other software required
-Not a large amount of hard drive space is required so i think a 60gb or 120gb SSD would suffice for now but with the option of adding a hdd later on.
-Although, aesthetics are not crucial, I am not looking for something vulgar or gaming based so just a simple design is preferred.
-I would prefer to build it, but obviously if it is possible to buy a pre-built with the same spec for less I would do that.
Uses:
-Internet surfing
-Word processing/excel
-Light gaming. My dad is kinda addicted to Rome total war, and plays solitaire all the time. I might buy him shogun 2 in the future but anything fps based is not ever going to happen. He wont be after high frame rates but it would be preferable. He is probably used to playing with a good solid 15 so not a huge increase is required
Thanks very much for taking the time out and i appreciate this is difficult criteria. Thank you
Things required:
-Screen
Uses:
-Internet surfing
