Low Budget Stream Encoder
12 Apr 2013
Birmingham
Hi all,
I would like to make a stream trans-coding machine to take the load of my main pc.
Basically I want to stream at a high bit rate but low cpu use age preset to a secondary PC running Ubuntu with Nginx as a RTMP server and ffmpeg as a trans-coder.
I would like you to spec me something capable of doing this job, all i need is the possessor, memory and motherboard (already have everything else lieing around).
Do not care between Intel or AMD, just needs to be as cheap as it possibly can but able to do 720p60 whilst still keeping up decent quality.
Thanks
P.S. I am currently using my mac book pro to do this and well... it just doesn't cut it
