Low bundle pc build
29 Aug 2011
My pc is pretty old and isn't up to date, i am not going for a high end gaming/media pc but i do enjoy watching videos and surfing the internet, also the only game i play is World of Warcraft on everything on low, i have been pricing some builds up also looked at the mobo bundle but i can't decide which one is a good one, only requirements i need is 5.1 sound ports and able to play wow on more then low. I am trying to keep the bundle to low as possible. Any suggests
whats your budget, and do you need just the core components,the full tower or evything including OS/monitor peripherals?
AMD Llano A8-3850 2.90GHz (Socket FM1) APU Processor (AD3850WNGXBOX) with FREE DIRT3 PC Game
MSI A75MA-G55 AMD Hudson D3 (Socket FM1) DDR3 Llano MIcro-ATX Motherboard
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Thats about £200
WOW is intel and nvidia biased. An i3 2100 and 460 like jony suggested would be the best build in my opinion too. Although the i3 is only a dual core it matches AMD phenom 2 quad cores for gaming performance.
If your pc is old you need to check your PSU too. It might be wise to upgrade that too. You also need to check your HDDs. Are they sata or IDE? Most mobos dont support IDE anymore.
Good luck with the upgrade. Any questions or problems just ask
do you already have the PSU?
if not theres better alternatives from corsair/antec here in OCUK.
if you already have it then, yes it will handle the system I speced.
