Low cost case fans
15 Jul 2012
Hiya, please spec me 3x120mm or 1x120 and 1x140mm fan to replace the ones in my Cooler Master Silencio 550 that I'm giving to a friend. I have the stock fans but they literally have 0 airflow and still manage to make click sounds.
Their rig is [email protected] and a 5850.
£20 budget but any decent CFM fan with lowish noise. Either white blue LED or plain.
The case can take a 140 in the front or 2x 120, but one fan is blocked by HDD cages so it's kinda pointless going for 2x 120.
Basically need two cheap fans, 140mm and a 120mm, cheers!
Would be nice if they match too. The Aerocool shark's look interesting but the 120mm version has terrible airflow and is out of stock.
Oh, also if you can recommend a new fan for their Tuniq Tower 120 that would be great! Something quiet with static pressure.
update: no replies, I think I will keep an AF 120 and put one of my new af 140 in the front and that will do just fine.
