Low cost upgrade help
18 Aug 2010
Scotland
Have an old Cooler Master 335 that I will be replacing the MB, cpu and ram and looking for something very low cost and so keeping it to max £285 with everything.
Potential upgrade:
INTEL Core i5 6400 2.7Ghz -- "already have arctic cooler"
ASUS H110M-A
Crucial - 8GB (1 x 8GB) DDR4-2133 Memory
Fan splitter
I understand my case is lacking USB 3.0 in front, but at least there will be a couple in back.
So keeping in mind I can't go above £285, are there any other choices?
Hi,
What'll be the main use/s of the system?
Does it have an SSD?
Already have a SSD, HD and external storage, so just the items listed are needed and this will be used for work and gaming - ie strategy gaming - TW Warhammer 1 and 2, Stellaris, etc with some fps.
My basket at Overclockers UK:
Total: £293.47
(includes shipping: £10.50)
You should have free shipping by now, I imagine.
Check http://www.asrock.com/mb/AMD/AB350M/#Specification for the correct specification (correct number of USB headers etc).
You'd need an AM4 bracket for your Arctic cooler, or use the AMD Wraith cooler.
Total: £293.47
I did not even look at that as I thought it would have been way over budget!
TY for your help :)
