Hi,
Just watched a report on BBC that shows the low energy lightbulbs contain mercury which means that they are considered "hazardous waste" and you can't just throw them in the bin if/when they fail.
Also more interestingly if one breaks you need to be careful :-
http://news.bbc.co.uk/1/hi/uk/7172662.stm
I find it incredible that after years of pushing these "low energy" bulbs to the general public that this advice is only now coming to light! ( pun intended
HEADRAT
Official advice from the Department of the Environment states that if a low-energy bulb is smashed, the room needs to be vacated for at least 15 minutes.
A vacuum cleaner should not be used to clear up the debris, and care should be taken not to inhale the dust.
Instead, rubber gloves should be used, and the broken bulb put into a sealed plastic bag - which should be taken to the local council for disposal.
HEADRAT
