Had an R9 390 which has been replaced under warranty with an RX 580 8GB.
I uninstalled the old drivers after removing the 390 and re installed and updated them after fitting the RX580.
But there's a bit of a problem, the GPU doesn't seem to be running properly, I've just checked the logs in Afterburner and GPU usage is stuck at 16%. Temp hasn't gone above 55 degrees, and even if I manually put the fans on to bring the temp down it's still stuck at 16%.
Are there some settings somewhere that I need to adjust?
