Low fps in Bioshock?
Ouch thats bad, single 320mb GTS in XP, and i get about 70 average maxed out 1280x1024, even goes into the hundreds, lowest ive seen is about 58fps, so id say SLi in Vista needs fixing. :p
Something's not right there, 8800u-SLI should murder BS most of the time at that res. Not using 16xAA or something are you?
That vsync bug is dead annoying though. I haven't touched the game in a couple of weeks.
Its just poor SLI drivers. It will be sorted out but if you look at XP track record it may take a while.
Im getting anwhere between 30-60 FPS throughout the game; it fluctuates quite a bit. This is at 1280x1024.
I expected my system to run higher frame rates than that but judging by this thread, Vista x64 is my main problem?
AMD6000+ @ 3.12Ghz
XFX Geforce 8800GTS 320MB
4GB DDR2 Tracer Ram
Gigabyte GA-M57SLI-S4 Mobo
Vista x64
AMD6000+ @ 3.12Ghz
4GB DDR2 Tracer Ram
Vista x64
playing in dx10 or dx9?
