when i played this game i think i had a GTX 285 or a 4870 cant remember now.Im on the beach (just after u make your char) and the fps is sitting around 30:/
Settings are set to High with x2 AA.
is that low for my specs? (see sig)
i have a weird feeling there is just something wrong with my computer -_- last few days ive played 3-4 games and ALL of them have had juddering... (lord of the rings online, AOC, Witcher, Risen) You move so far and then it stutters/judders. >< Maybe its the hard drive -_-
Thanks for your help im running a defrag sto try and help it out a bit but then ill try them settingsty
DX10 is still in test mode. Doesn't look any different than DX9 anyway.
Also your Ram could be the culprit try to run some tests download "Memtest" and run the Windows Diagnostics memory test.
You can also check your HDD for errors by downloading "HD Tune"
And the most obvious, but im sure you have checked is temperatures of the video card and your CPU
shadows rape fps iirc
When i was a wow addict ..3 months 3 days 1 hour since i last played wo..-sigh- ... Lol with shadows on max my fps allways dropped below 45 even tho i had a pc that was 10x stronger than Suggested spec! Wonder why shadows lower fps so much on online games :/ itw as same for LOrdo, champions online + parts of aion.
Thanks ill tyr out the teeak guideBest tip i can give for smoothing out on your setup is to max all your view distance sliders and high quality distance sliders. Sounds strange but the way the game engine calls textures an LoD models has a massive hit on performance. On your hardware maxing them out should actually improve performance.
Didn't this game fail?
