Low FPS
5 Apr 2014
HI i have i7 4770k, gtx 770, 16 gb ram, Z87-G45 GAMING, power flower 750 gold 80+ and i get 20+ fps in Arma 3 i asked some people is it good or bad and they say its bad could anyone tell me what could be the problem??
Before we say if its good or bad, what settings are you using in game?
what resolution are you playing on?
are you using the latest drivers?
the 770 is a good card but arma 3 is a very gpu intensive.
Neither of those dropbox links work....
What OS are you using?
What version driver are you using?
Are you having issues with other games?
You need to give people as much detail as possible otherwise how can anyone help you?
Yeah, LoL and Arma III are very, very different!
You should probably try altering some settings like ultra to just high/medium. Failing that, google some guides on getting the best performance.
Also, I'm guessing that Nvidia haven't got a "Geforce Experience" profile for your card? The profiles are generally pretty spot on with getting the visual fidelity and speed about right.
You will not be able to play everything on ultra with a 770 it in that game it just wont do it, go into g force experience and click the optimise button for the game.
If as above go into the game and set everything to high if, it still struggles medium the 770 is a descent card but not powerfull enough for that game on ultra.
