Low frame rate with 770
12 Oct 2012
London
For the past months or so ive been using a borrowed 7950 and i brought my card and its an Asus 770 CU2. When ive been playing battlefield 4 on the 7950 its been staying around 80-90 fps on high settings but soon as i changed to the 770 on high i only get 40-60 and it drops even lower in busy areas. I know the game favors amd but surly it cant be that bad? Are there any fixes for this issue?
that is strange as i swapped my 7950 to 770 and my frames are higher . using 331.82 drivers didn't go with wql ones as someone reported they not super stable and i didn't have any troubles with these
80-90 I assume had details lowered? The 770 is a good card and you should be hitting higher frames if you was using the same settings. Did you clear out all the AMD drivers with DDU? It could be a confliction there.
Im using 332.21 drivers at the moment, I sure something is wrong because every other game i try i get around about the right fps, even on low settings im getting only 70-80
I did a fresh install when i put the card in,Im going to roll back my up driver version and hope i get a fps increase, with the 7950 i had msaa off and effects off to get 80-90 most of the time but didnt really drop lower than 70 much, I tried the same with 770 and was getting below 50 at times
