Low GFlops with overclocking
Man of Honour
4 Jul 2008
hi folks,
wondered if anyone would be able to shed any light on my issue atm.
Basically, to sum it up with a picture:
It's passing the tests as "stable" but for some reason the GFlops output is very low compared to others running same clockspeed. It sorta suggests that the CPU isnt running as it 'should'?
I can't for the life of me fathom why.
Any ideas?
Im not particularly familiar with Intel however that would suggest thermal throttling of some kind if others are seeing Higher GFlops than that.
It is low for that clock, yes Big.Wayne.
@MooMoo444, run Linx again, but this time select ALL available ram to use.
In your screenie you are showing a "Problem Size" of 11530, if you have 6gb of ram, the problem size should be over 25000. That should then increase the GFlop figure.
make sure your EIST and C1E are disabled in the bios if you have such option.
Your theoretical maximum GFlops: 16 x 4 = 64GFlops. But this is only ideal value. Imo acceptable values should be around within 70% of the theoretical maximum so you should be getting around 45Gflops minimum.
You should also turn off antivirus when running the test. It also depends on the quality of mobo, chipset, components etc.
Check out my thread about running such stress tests in which I also quoted an excellent article on ensuring you get higher Gflops :):
http://forums.overclockers.co.uk/showthread.php?t=18206940
Seems a tiny bit better with higher RAM usage but somethings definitely a bit off. Temps arent going above 80 so I doubt it's thermal throttling.
I'll try it every day for a few days see how it changes. If no improvement I'll either reformat windows or take PC apart and build it again, just to take those out of the equation <_<
When I run Intel Burn test sometimes I get lower Gflops. Then I stop the test and restart it again and get higher values. So you may have to keep stopping and starting the test several times to see if that makes any improvements.
With certain earlier versions of IBT, there was a bug with thread detection if left on auto iirc.
I had a problem with a version of intel burn test in that it was passing but then unstable in use. The gflops value was lower than Setter's iirc. Changing to a newer version increased the gflops figure to a more standard one then crashed.
So I think changing to a different version of linx is the way to go.
It could also be turbo doing something inconvenient, like deciding the chip is drawing too high a current so it'll only use the higher multiplier some of the time.
But I'm using linx, not burntest :confused:
Any idea what version of linx is a good one then? I just googled the latest yesterday.
Found an interesting comparison thread while googling;
For an i7 above the 4ghz barrier, 51-60gflops seems like the normal values.
My CPU is handicapped and I can't work out why :(
Are your sure the OC is fully stable?
Have you passed at least 20 runs at "all" memory?
Have you tried adding a little more Vcore?
I find the the cpu will give lower gflops if it still needs a little more vcore.
If you close down some programs that are not needed while testing you should be able to use 25k problem size which will also give higher flops.
Didn't give up on this!
I updated the bios to the most recent one, and I also reinstalled windows incase I'd mucked up chipset drivers or something.
Seems to have fixed the problem, so it was all worth it!!
Looking much better :cool:
