Low GPU load BFBC2
13 Jun 2009
Chesterfield
Hey guys ive got a 460GTX and for some reason i have a low load in BFBC2. In other games my GPU gets to about 71c but in BFBC2 its sitting in the low 40's x I cant play this game with any AA and this is with an i5 and 460gtx.
Any idea to what the problem might be?
what cpu do you have?
i can run at a solid 60fps with everything on high, DX11 2xAA & 4XAF with HBAO on.
system is a AMD Nom II x4 965 black edition @ 3.8ghz and a EVGA gtx 460 768mb sc
(only running 1360x768... hd tv n all that)
edit:
From another forum said:
Try this, go into My Documents/BFBC2/settings.ini
and change "RenderAheadLimit" to 4
Try everything from 0-4 and see which produces the best results.
edit:
will try this. I have a i5 760. Will also add I did a clean re install of Nvidia drivers and the game ran flawless . Reset the PC and its back to doing this
check your settings ini in Libraries/Documents/BFBC2/settings
here is mine for comparison
Width=1920
Height=1080
Fullscreen=true
RefreshRate=60
VSync=false
[Sound]
Quality=medium
VoipEnable=true
SpeakerCount=6
[Graphics]
Effects=medium
Soldiers=medium
Vehicles=medium
Overgrowth=medium
Undergrowth=medium
StaticObjects=medium
Terrain=medium
Shadows=low
Bloom=false
HSAO=false
MSAA=1
Water=medium
MainQuality=custom
Texture=high
DxVersion=auto
Aniso=2
Detail=medium
RenderAheadLimit=2
Fov=55
check in particular what these are set to
Bloom=false
HSAO=false
but does sound like you are having issues with graphics drivers.
