Low GPU usage when running CPU @100% with Prime95...
8 Aug 2010
Essex
I've just payed about overclocking my GPU & thought I'd put my system through it's paces with a couple of stress tests.
I ran Prime95 on the blend setting stressing CPU & RAM making my 2600K sweat a bit, and ran EVGA's OC Scanner to get my GPU running as close as possible to max.
However, I found that while the CPU was maxing itself out, the GPU was held back by something. It seemed to hover around the 50-60% usage figure and occasionally sometimes below that.
Any ideas why this is?
My rig is in my sig.
Were you running the prime95 cpu and ram test at the same time as the evga oc scanner test. If so then your gpu was being bottlenecked by not having enough cpu power to push it to the max.
