low level format for usb hard drive?
29 Jul 2003
hi
i am looking for a software for win7 laptop so i can do the low level format on usb external hard drives.
which one you would recommend?
thanks
Use diskpart
CMD >
Code:
diskpart
list disk
select disk (number of correct drive here)
clean all
the "all" switch for clean tells it to overwrite - or 'zero' the whole drive. Without this, "clean" just overwrites the MBR and partition tables.
You can then set up the drive with these further commands:
Code:
create partition primary
select partition 1
active
format fs=ntfs
assign
exit
