Low low light photography [no judges]
1 Mar 2003
Cotham, Bristol
Stage photography after dark, so all there is is the stage lighting. I tried this this weekend, I had to use a relatively quick shutter speed (1/60) as they were dancing pretty quickly.
I also used the largest aperture possible (f4), I would have liked to use ISO 800 but it was just to dark so ended up using ISO 1250, which made all the pictures unbearably noisy.
The picture below is probably one of the better shots, albeit perhaps off focus and noisy :(
Any more tips for this type of photography would be helpful :)
in my opinion, f4 just isn't wide enough for low-light like this. i operate between f1.8 and 2.8, ISO800, around 1/25 - 1/60, and im really happy with the results i've started seeing. it's also worth upping your contrast and balancing out the exposure.
try and get yourself a 50mm f1.8, they're under £100 and they're excellent lenses for this type of photography - don't be afraid to use slower shutters as they pick up the movement well :)
The 50mm/f1.8 is a cracking lens , With mine I don't need to bother with flash indoors unless I'm going for a large DOF.
If you fiddle with the levels you can pull quite a bit more out of your shot (come out a bit blocky , would be better starting with full res image :))
Yup I shall def look into, mrgubby I think I prefer my contrasted one. The overall tone, colours and lighting looks nicer imo.
Fair enough :) , was just trying to pick out the extra detail , never bothered with resetting the colours/saturation :)
It looks all grainy now and the colours are bleeding too.
Paul, if you run that contrasty image through noiseware, you should get a better-looking result :) also, play around with the shadows/highlighting to get some more detail around her face
I've only got the trial version :(
