Low noise margin?
12 Dec 2005
Hi guys,
Been having issues with my connection today as some pages take ages to load and end up timing out.
Google and Overclockers forums seem fine though.
I thought it might be a problem BTs end but I checked my router stats and not sure if these are normal.
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 3.6 dB / 5.7 dB
Line attenuation (Down/Up) 29.5 dB / 12.7 dB
Output power (Down/Up) 0.0 dBm / 12.9 dBm
Cheers
It's quite common for some routers to list the output power as 0....
As for your margins, they look fine. Have you tried a simple reboot of the router or can you try another machine?
Edit... and what DNS servers are you using?
Yeah I've rebooted the router many times, the other PC's in the house are the same aswell.
What are DNS Severs?
