OCUK, need your advice please
2011 BMW 1 series 2.0L E88
It was a bargain (£1900)
Has run beautifully
Today on an A road doing about 70mph, the dreaded red oil light came on the panel
I pulled over at the first opportunity.
Quick google suggested "Low oil pressure" and "do not continue your drive"
I wanted to check the oil pressure but it's a digital check that requires the engine to be running.
Car started no issue, oil was at ideal level (and not leaking any) and no sign of the light.
I crept it around the local roads, no sign of the light
I left it a couple of hours then took it on a gentle A road jaunt, about 10 miles, keeping everything sensible, no sign of the light
No knocks, bangs or unusual noises, no smoking, seems to be running normally
Any ideas? Should I keep it garaged until a chance to get the local BMW indy to look (in about 10 days time)? Reckon it's safe to drive carefully for a bit? Any thoughts why the light would come on just once and then seem to calm down?
Thanks!
Has run beautifully
Thanks!
