- 23 Aug 2008
Hi,
I'd originally posted my problems in cpu section, I've had a Q6 at 3.6 1.3v for a few months now and all was well, I was toying with the new Ati tool and my 4850 when I noticed my benchies were down a heck of a lot (5k down on 06 ! ) running through everest, super pi, fritz I noticed my cpu was hitting roughly half or just over what it used to do.
I've followed the normal route, cleared cmos, checked and re checked o/c settings voltages etc. I've even reinstalled XP Pro SP3 and flashed my bios to the latest revision. all to no avail
now TAT is showing two cores at uneven speeds, one is showing as 3200 which is correct as per current bios settings 8 x 400, the other is showing as 1800 ? had it been 1600 ( half of 3200 ) at least I could have seen some logic, temps are fine, power is fine, b ut I'm at a total loss as to why this is happening, please does anyone have any ideas or has anyone had a similar problem ?
Thanks in advance
*edit* forgot to add eist / speedstep disabled
Thanks in advance
