- 8 Oct 2008
I am after a low power amd card. Need it for a header to admin vm's for Nv cards in a workstation
It will pretty much idle 99% of it's life. ram/performance is not important.
Power consumption/noise/heat is.
Is the r7 240 the lowest power amd card available ? or is there anything from the new generations that is power efficient ?
.It will pretty much idle 99% of it's life. ram/performance is not important.
