A friend of mine has a shop bought PC with the following spec:-
Intel C2D E2140 1.6GHz
160GB SATA Hard Disk Drive
RAM 1GB DDR2
SiS Mirage 3 on-board Graphics
Onboard Audio
DVD-Writer - DVD±R/±RW
Vista Home Premium
He also has a 19" widescreen monitor with a native res of 1440x900
He is wanting to upgrade to a dedicated GFX (PCI Express).
He doesn't do much in the way of gaming and will be watching films. The problem is he tells me that his PSU is only 250W.
He has £100 to spend in total but ~£30 of that is going to go on 2x1gb of RAM. Before he told me of his PSU Wattage I was looking at something like this as it is bang on budget, wil be able to handle the 1440x900 res, will handle high-def playback and also has the added bonus of 5.1 Audio :-
http://www.overclockers.co.uk/showproduct.php?prodid=GX-081-PC&groupid=701&catid=56&subcat=416&name=PowerColor%20ATI%20Radeon%20HD%203850%20Pro%20Extreme%20512MB%20GDDR3%20TV-Out/Dual%20DVI/HDMI%20(PCI-Express)%20-%20Retail
However it states "450Watt or greater power supply with 75 Watt 6-pin PCI Express power connector recommended."
So can you reccomend a good alternative that is <£70, will run on his current PSU and have no probs with films/light gaming at a res of 1440x900?
Thanks in advance.
RAM 1GB DDR2
Onboard Audio
Vista Home Premium
Thanks in advance.
